Apologies for the long post, but there is a lot going on with this old fireplace.
Seeking honest guidance if this is a DIY fix or a project to bid out. I purchased a 1945 bungalow with decades of previous DIY fixes. The working wood burning fireplace is a great example. It was originally a heatilator that has been converted to a steel firebox by a previous owner. They sealed the side vents, cut out the center pipe, and made modifications to the chimney. Inspector and chimney sweep said it is olddd but usable and has worked fine for infrequent fires since I purchased it.
That is not the current problem, however. Before launching in, I will share that the house foundation had settled and caused separation between the hearth and the fireplace. The foundation has been professionally stabilized since the purchase.
I am updating the fireplace façade and started to remove the brick hearth with the intention to fill with concrete for an updated look. The concrete pad under the old brick is crumbling and several holes appeared while removing the bricks. Through the holes I can see the ground and vapor barrier (I have a pier and post foundation). There is a triangular steel frame running through the center of the hearth and a rusty steel pipe running from the point of the triangle to the footing. There is also a separation gap between the crumbling concrete hearth slab and the wooden subfloor on the sides.
Questions: Can I knock out the old concrete around the steel frane and pour a new hearth? Or do I have to add support to the hearth underneath?
What would be the best method to rebuild the hearth?
Photos attached. I am sure they will give you a kick! Thanks in advance!
![Crumbling hearth salvageable? Crumbling hearth salvageable?](https://www.hearth.com/talk/data/attachments/276/276213-32e64df3fa68371d0b4a4075d933b533.jpg)
![Crumbling hearth salvageable? Crumbling hearth salvageable?](https://www.hearth.com/talk/data/attachments/276/276209-a5dbea545367a788a8294fe8e1557dff.jpg)
![Crumbling hearth salvageable? Crumbling hearth salvageable?](https://www.hearth.com/talk/data/attachments/276/276210-5008545285be34a578e0a4228262e3ad.jpg)
![Crumbling hearth salvageable? Crumbling hearth salvageable?](https://www.hearth.com/talk/data/attachments/276/276211-611ae40db712b8f94c86d09839725e0d.jpg)
![Crumbling hearth salvageable? Crumbling hearth salvageable?](https://www.hearth.com/talk/data/attachments/276/276212-debbc4e40d8296a43e2c734f1eb6d5ed.jpg)
