Cresote cure?
alfrehner
17
Northern Missouri
I heard an old wise tale the other day and thought I would run it past all the experts on here to see if it is true or just a tale. I was told if you burn an aluminum can in your stove it will clean the cresote out of your pipe. Something to do with the fumes it puts out? I was just curious if anyone has ever tried this or was he just pulling my leg?
hehehe
  • [Hearth.com] Cresote cure?
Cresote cure=stop burning,and be willing to freeze your buns off. :lol:
Seriously, burn hot and burn clean dry wood and no "worries mate"..
Nothing will take the place of proper burning techniques. It's just like auto maintenance. They have yet to make a "mechanic-in-a-can".
A better suggestion? Drink whatever is in the can after you've finished cutting next years wood.
Ditto all that. I only burn dry stuff and make a super hot and controlled fire every day. No prob, Bob! :coolsmile:
the cure is free and available its called "time" , gotta use dry wood .in a nut shell creosote is caused by moisture
