Nah, a couple wonky fires does not a creosote problem make. Clean your glass, toss whatever splits like that you've got left off to the side, and save 'em for next year.
You should be checking the flue regularly to see if it needs to be swept no matter what you burn.
Green wood doesn't have creosote in it; green wood uses a lot of energy to boil off water, so it burns cooler, which means lower flue temperatures. Creosote is (in this case) wood tar that didn't get burned off, and subsequently condensed on a cool surface. The cooler your burn, the more creosote you are getting.
If your green wood went onto a roaring fire and burned hot, you probably didn't incur any buildup. (But inspect your flue regularly anyway.)
Great advice, but make sure to check the top of the flue/chimney as this is where the majority of creosote deposits itself, due to cooling more from being further from the stove and being exposed to the outdoors.
