Creosote control chemicals
Rob_Red
397
Southern New England
Hey everyone, I’ve heard from a few people that the products that chemically convert creosote to a dry powdery substance work well and are recommended.
are these safe for use with a catylitic stove? Some products say to burn the product with the bypass on and the cat inactive. Hearthstone does not recommend using the stove for long periods with the by pass on and they say don’t burn anything other than cordwood.
should I use this product?
What do you guys think?
I have used Cre-Away. If you have glazed creosote in your chimney, first remove the catalyst from your stove. Then build a small fire, not a real fire just enough to heat the flue up to 300 degrees or so. Keep the bypass open. Puff the Cre-Away up the chimney through the bypass damper. Use a decent amount so it coats the whole inside of the flue. Then let the fire die out and sweep it clean.
I've had to do this once after a batch of not-so-well seasoned wood, and it worked. I would not bring this stuff anywhere close to the catalyst. And I would also not use it regularly, just when you have glazed creosote that you can't remove using a regular brush.
