Creosote buildup on Stanley Waterford Errigal Wood Cooker
justinemtp22
8
Southeast MA
I have an older Stanley Waterford Errigal Wood Cooking stove. It's new to me and I'm just getting used to using it. I noticed today that after keeping a fire burning for about 2 days that there is quite a bit of creosote buildup under the round hotplate cleanouts on the right side. I'm burning mostly seasoned hardwood with a few wetter than normal pieces once and a while. I'm just wondering if this buildup is normal and if so how often do I need to clean it out. This type of stove is completely new to me so any help would be greatly appreciated. Thanks.
Some wetter than normal pieces. some times some pieces is all it takes. I can always tell when my girl dont walk all the way to the good wood stack, and trys to cheat with unseasoned pieces due to the sheen on the glass. A little aint too bad, but a little every day can add up. Whats the chimney setup look like?
The chimney is stove pipe 3' straight up, 90deg to the right and 3' more of stove pipe directly into the chimney. I checked the stovepipe and chimney and it seems fine.....but the buildup inside the right side of the stove (opposite of the firebox) is a lot of real shiny creosote.
I found the problem. The passageway that goes from under the oven, then behind the oven up to the flue was almost 100% clogged. Once I cleaned that out it ran a lot better and no more creosote buildup.
