let me c if i can get a pic..brb..
maybe guys here can help me decide to replace em or not?....saw was flooding out on me after runnign it for 20 minutes or so...it was running perfect for those 20 minutes then would die...then hard to start due to flooding....i had the carb rebuilt...its alot better doesnt die on me, but does seem to flood on restart sometimes .......i was thinking crank seals.....any ideas?
not sure...all i can tell u after it does flood i can clear the cylinder by pulling plug and turning to off position and pulling the cord several times...then it fires right up...how can i check it?
fuel filter and line will be replaced next....then i will go ignition coil if that doesnt fix it
Hmmm, If the saw re-fires right after you clear it (less than 5-10 min from the time it dies) then I'm not inclined to think ignition is the sorce of the problem. But a quick check for spark immediately after it dies is quick and cheap to do.
After the carb re-build, are you saying the saw no longer stalls out while cutting but now floods when you try to restart it?
Leaking crank seals will tend to lean out the mixture but if someone adjusts the carb to try and compensate (adjustment will be very finicky) there may be times the saw runs excessively rich.
Those rings look awfully shiny, could be camera flash but they could be worn as well. Steeltown, you've mentioned this saw acting up before and I suggested a compression check. I highly recommend you do a compression test on this saw now with these symptoms.
Steeltown's rprevious thread -
https://www.hearth.com/talk/threads/stihl-460-acting-weird.87935/#post-1139443
Double Hmmm...... Finicky carb adjustments, shiny rings, stalls when hot, piston shows signs of heat (brown could be oxidized oil) , yeah this thing needs a compression check at the very least if not a complete crankcase pressure test. (which would also tell you if your crank seals were leaking.... )
If the cylinder bore size and piston checks out, you may be in for just a simple re-ring and you're back up and running.
