Crane Coal Cooker question
bgreene
1
eastern MA
Hi,
I have the opportunity to get a Crane Coal Cooker Model 44 for free. I have a fireplace that I hardly ever use and am considering using it for this purpose. I have the following questions:
- My city requires that I get a permit for it and that its installed according to the installation instructions for the stove. However, I don't have that document. Does anyone know where I can get it?
- My fireplace has the typical vent that I can open or close. How do people install a coal stove in a general purpose fireplace?
- I'm assumming that I can get this professionally installed. What is the typical price range that one pays for this?
Thanks
That is a relatively standard batch-fed coal stove - made here in Ma. as I remember. They were well regarded in the industry.
You might be able to dig up a manual......at that other site - from an owner.
As far as installation into a fireplace, the best job would entail a full liner of the existing chimney- assuming it is an exterior masonry chimney, with stainless steel pipe. This can be flex, rigid or a combo of the two. A block off plate would be installed below the damper - made of sheet metal - with the pipe passing through it.
Make sure you upgrade the liner to one which is rated for coal use. This usually means a 316 grade of stainless steel.
Found this pic of one Crane model on craigslist
  • Crane Coal Cooker question
No problem. I reduced the file size for upload here.
  • Crane Manual Model 44.pdf
Reactions: doug crane
