I have a 40cc Craftsman chainsaw (Model # 358.360130) that ran great all spring for cutting a tri-axle load of logs for firewood. The saw is 8 years old and was only used for light work before this year. At the end of the summer, I was working on two larger trees when my saw would not start. After a couple of repair bills for cleaning and replacing the starter cord assembly, I took the saw to a different shop and was told that the piston is scored and the saw is junk. I removed the muffler and looked at the piston. I does have marks running down the side which I expect should not be there. Is it worth buying the replacement parts for this saw? SearsDirect has the cylinder for $45 and the piston for $20. I would not attempt the repair myself and would need to pay a local shop. Is it worth repairing this saw? I'm planning to buy a Stihl Farm Boss to handle the work load for the spring but I would like to have the smaller saw for smaller jobs.
A note to anyone considering a Craftsman saw. We bought a new Craftsman for my father-in-law. We only ran the saw four or five times (several hours each time) before it would not start. It had a scored piston. Since it was past the warranty period, we could not get the saw repaired. He traded it in on a Jonsered. I would not buy a Craftsman unless you are only planning to use if for light work. Both repair shops told us that the piston looked like we were running straight gas with no oil. We were using mixed gas that worked fine in other saws and a weedeater without any problems. Apparently, the Craftsman saws got too hot or took in dirt which ruined the piston.
