I have a wood furnace that I'm currently running duct work for.
Could you take a look at these pictures, and tell me if you think I'm doing it ok?
This is a basic layout of my house, first and second stories. My house is 1400sqft.
First Floor
(broken image removed)
Second Floor
The red are forced air ducts, the blue are return air ducts.
I'd like someone to look at my ducting system with me, and tell me if I'm going about it right.
The first floor, atleast all but the utility room, has a 3 foot crawl space under it. That is where all the ducting is being run. In the garage I am installing a plenum, and each down stairs vent has a six inch flex-duct ran to it and then comes out of a trap door into the garage. I believe this is called an "octopus" system, much like how coal furnaces were setup. I chose the route because I live by myself, and I wanted the option of being able to control the flow of air to each room individually. Also, because I am inexperienced with running duct work, and after speaking to a professional, was told this was the easiest way to not screw it up. Running a single core line and branching off of it is much more of a science.
The forced air that goes to the utility and bathrooms are being ran through the wall from the attached garage and tie into the system out there at the forced air plenum.
The first floor cold air return lines each will have a 8" flex duct ran to it, and again, to an insulated plenum in the garage, which then attaches to the furnaces blower.
As for the upstairs, it is about 1/2 the size of the downstairs. Its being fed by a 4x12" square duct that I ran up the inside of an interior wall. That then lets off into 2 6" flex ducts, one of which runs to either room. The return line is a seperate 4x12" square duct, and terminates in the upstairs bedroom. All of the upstairs ducting is contained within the attic space to the left of the bedroom. Both of the 4x12" ducts let out into the crawl space and attach to 8" flex pipe which is then ran to one of my two plenums.
Do you have any advice on anything I should add to this duct system?
First Floor
Second Floor
