Smitty said:okay, another potentially stupid question, looking at page 15 for firebricks its stating i should have
(19) full sized bricks 9 x 4.5
(2) 9 x 3.5
(1) 7.25 x 4.5
what I have is
(17) 9 x 4.5
(2) 9 x 3.5
(2) 9 x (2.5 on top 4.5 on the botton) -its slanted
(1) 4.5 x 4.5
(1) 4.5 x 1.5
now for the back I am left with the (2) 9 x 3.5, the two slanted full size guys, and the two small ones, am I missing something obvious here?
Yeppers , The "cotton" looking baffle stays. Your secondary burn chamber at the top is a "floating" fire box and sits on the side rails and hooks to the air inlet tube in the back , make sure you have a gasket where the secondary burn chamber meets the back wall air tube inlet and the gasket is always in good shape. The cotton looking baffles go to the sides of the the burn chamber to fill the gap and it lets the burn chamber moves as the stoves heats and contracts.Smitty said:I finally got my summit installed and was putting the firebricks in and noticed in the top left and right corners, running to the back of the stove, there is a cottonish looking roll of stuff, does that stay or go?
Roospike said:Yeppers , The "cotton" looking baffle stays. Your secondary burn chamber at the top is a "floating" fire box and sits on the side rails and hooks to the air inlet tube in the back , make sure you have a gasket where the secondary burn chamber meets the back wall air tube inlet and the gasket is always in good shape. The cotton looking baffles go to the sides of the the burn chamber to fill the gap and it lets the burn chamber moves as the stoves heats and contracts.Smitty said:I finally got my summit installed and was putting the firebricks in and noticed in the top left and right corners, running to the back of the stove, there is a cottonish looking roll of stuff, does that stay or go?
I couldnt figure out what you were talking about and i looked back through some threads. I think i might of mentioned the back air tube is Stainless steel. its is not. The back tube and the back rail are are standard steel. The side rails , the top secondary burn chamber , the top plate above the secondary burn chamber and the front air inlet are all stainless steel. The back tube and rail are mounted and are part of the body of the stove.minesmoria said:Roospike said:Yeppers , The "cotton" looking baffle stays. Your secondary burn chamber at the top is a "floating" fire box and sits on the side rails and hooks to the air inlet tube in the back , make sure you have a gasket where the secondary burn chamber meets the back wall air tube inlet and the gasket is always in good shape. The cotton looking baffles go to the sides of the the burn chamber to fill the gap and it lets the burn chamber moves as the stoves heats and contracts.Smitty said:I finally got my summit installed and was putting the firebricks in and noticed in the top left and right corners, running to the back of the stove, there is a cottonish looking roll of stuff, does that stay or go?
The back side rails look rusty on its stainless steel whats going on?
Awesome , mystery solved.I noticed your angle cut bricks still on the floor.........I'm sure you took out the full bricks on the bottom and noticed the angle cut brick go to the back bottom on the right and left ? Hey i remember when my stove was that clean. Do me a favor there Smitty if you would. Take a picture & post of your Summit showing the steel top of the stove to show how thick that monster top is. Mine is covered and i thought it would be a good picture to have on hand for the forum. LETS SEE THE INSTALL TOO ! :cheese: If you have any other question ...........were always here .Smitty said:ah! mystery solved, the printed instructions included with the stove do not match the bricks, downloaded a pdf of the instructions from PE and it matches the bricks
Im guessing if I had an ash cleanout system installed I would notice it?
Well that justs absurd ..........Put a candel in your Summit in durning the Summer. Sound like some kinda a nut case. :sick:Willhound said:OK, I wasn't going to bring it up, but.....since Warren already did.......
If you put a candle in your Summit so you can look at the flames through the glass during the summer...you might officially be a Summit Junkie.
Welcome Brother!
Thats a good price there BB . $2195. WITH gold door and FREE shipping. The Chimney sweep on line prices are real good and they are $2275.00 + $30.00 EPA tax + $$365.00 shipping to your door. ( $2690.oo ) That Ebay seller has been around for a wile selling stoves. (Ebay Member since: Jan-23-99) Saving $495.00 is $495.00 and thats a lot of cha-ching. ALSO that would mean you would only need to have 3 splits of wood for the whole YEAR to heat your house ! ;-)BrotherBart said:If my fireplace was one inch wider I would probably have one of these Summit inserts on the way.
(broken link removed to http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200028294897)
I don't exactly know what the guy's game is. PE does not list him as a dealer and his place isn't in the Hereford, TX phone book that I can find. But $2,195 freight paid and no local sales tax would be tempting. I would have to keep it quiet because my uncle is a hearth dealer in that same town.
Of course I will probably buy a Vogelzang just to drive the Forum nuts.
