Water pump gone bad? Thermostat stuck closed?zapny said:The levels are fine but the light comes on right after you start the Rhino up, any thoughts.
zap
Danno77 said:Water pump gone bad? Thermostat stuck closed?zapny said:The levels are fine but the light comes on right after you start the Rhino up, any thoughts.
zap
zapny said:Danno77 said:Water pump gone bad? Thermostat stuck closed?zapny said:The levels are fine but the light comes on right after you start the Rhino up, any thoughts.
zap
We have the oil changed this time of year at the local dealer so we will have him check it out, screwed up todays plans.
Thanks
Zap
raybonz said:zapny said:Danno77 said:Water pump gone bad? Thermostat stuck closed?zapny said:The levels are fine but the light comes on right after you start the Rhino up, any thoughts.
zap
Thanks
Zap
Where is the coolant sensor located? Maybe you have a loose connection or a bad ground..
Ray
Danno77 said:Hopefully it's just a sensor deal. It is weird that it comes on right away. Usually the engine would have to warm up before a stuck thermostat or bad water pump would let the coolant heat to a point that would send the light off.
pen said:Are you checking the reservoir bottle and the radiator?
I had a kawasaki mule that did this for a day before I realized that it was blinking because the radiator was low and the reservoir bottle's coolant wasn't getting drawn in. Can't remember now if the line connecting the two was kinked or sliced, but regardless, just a thought.
pen
zap
zap
that's what I was hoping since it came on so fast (like before the engine even warmed up)zapny said:Danno77 said:Water pump gone bad? Thermostat stuck closed?zapny said:The levels are fine but the light comes on right after you start the Rhino up, any thoughts.
zap
Just called, it was only a sensor, back in action with the Rhino for the weekend! :zip:
gibir
Danno77 said:that's what I was hoping since it came on so fast (like before the engine even warmed up)zapny said:Danno77 said:Water pump gone bad? Thermostat stuck closed?zapny said:The levels are fine but the light comes on right after you start the Rhino up, any thoughts.
zap
gibir
raybonz said:Right on Zap! Had a few of those croak in my cars/trucks over the years..
Ray
zapny said:raybonz said:Right on Zap! Had a few of those croak in my cars/trucks over the years..
Ray
Had one in the wife's truck go, this is only the second one I can remember. How was the wind your way?
zap
raybonz said:zapny said:raybonz said:Right on Zap! Had a few of those croak in my cars/trucks over the years..
Ray
zap
Was pretty gusty today but at the moment it has subsided.. Gotta pick up some spare bungee cords for my shelter soon..
Ray
