I am new on here, and new to wood stoves. I have no experience and am a girl so I don't understand all the technical stuff. I do, however, want to buy a wood stove that can heat this kind of structure:
http://www.geoshelters.com/index.php?option=com_content&view=article&id=50&Itemid=57
It would be a geodesic shelter like this, 24' or 26' in diameter (not necessarily the one from this website), which equals 452 or 531 square feet. I would like to be able to heat in a range of a mild to extremely cold environment. Also, it will be the main source of cooking for a family.
So basically I need something that is easy to transport that can cook and heat this kind of space!
I don't even know if I should do steel or cast iron, although it seems like cast iron doesn't get as dangerously hot to the touch and radiates heat better?
What about this one?: http://www.ruralking.com/box-stove.html
Or this?: http://houston.craigslist.org/for/2634687705.html (can you cook on that?)
If I use steel, would something like this stand up to long term daily use?: http://www.outfitterssupply.com/Kni-Co-Alaskan-Deluxe-Sheepherder-Stove-Package/productinfo/WCS225/
I appreciate any advice or suggestions on which stove to choose. I would like to spend less than $800, and MUCH less if possible. I don't know anything about efficiency or btu's needed, and I don't know how to determine if it is well constructed and well sealed.
Thank you for any and all help
