(Pictures below)
-Hey guys
Had a few questions about converting an original wood burning fireplace back to wood burning from a gas insert conversion.
I have pulled the insert, gas line and electrical from the fireplace that was installed for the gas conversion as well as took the intake and exhaust lines out of the chimney.
When they did the gas and electrical install they drilled a couple holes through the original metal firebox walls. I was wondering if any one had any ideas on how to plug these back up, other than patch welding over the holes that were drilled? I was thinking of getting a few short lengths of threaded pipe just long enough to fit through the holes and then capping the ends and using washers and high temperatures sealant between the caps and the walls of the firebox. Thoughts?
Also, the fire place hasn't been used as a wood burning fireplace in at least 20 years and was very rarely used to burn wood before the conversion. Should I still have it inspected or will it be fine as is. I looked down the chimney from the roof with a bright light and the chimney looks spotless with no cracks or missing mortar as far as I could tell.
Thanks
-Rex
Holes drilled for gas and electrical that I need to block off.
![converting original wood burning fireplace from gas back to wood chimney looks spotless with burning converting original wood burning fireplace from gas back to wood chimney looks spotless with burning](https://www.hearth.com/talk/data/attachments/185/185876-4a3ee0eeceb5a82128205541df42691b.jpg)
View of chimney from the roof
![converting original wood burning fireplace from gas back to wood chimney looks spotless with burning converting original wood burning fireplace from gas back to wood chimney looks spotless with burning](https://www.hearth.com/talk/data/attachments/185/185874-ca446adebff9288daaf30409109ffc41.jpg)
Gas insert removed
![converting original wood burning fireplace from gas back to wood chimney looks spotless with burning converting original wood burning fireplace from gas back to wood chimney looks spotless with burning](https://www.hearth.com/talk/data/attachments/185/185875-bbc067e9eb4c98a26416d43d8f46a348.jpg)
-Hey guys
Thanks
-Rex
![converting original wood burning fireplace from gas back to wood chimney looks spotless with burning converting original wood burning fireplace from gas back to wood chimney looks spotless with burning](https://www.hearth.com/talk/data/attachments/185/185873-8e20e1fe2b9f03201304a32f99cdd413.jpg)
Gas insert removed
