I have a brick and mortar fireplace built in 1970's that at some point had a gas line installed to a stack of ceramic logs. We had a horrible general contractor come and replace the fireplace screen doors. When the contractor left, it was discovered that he removed the the throat damper. I started looking into a cap mounted damper but was concerned about the fireplace filing up with gas if pilot light went out. I think that i should just find a replacement throat damper but seems I cannot find much info on finding the correct type/size replacement and install instructions. Any pointers would be greatly appreciated. Thank you!
