Not even sure this is possible, and will it work? But... I have a wood boiler with a hot water coil insert. Do you know of any way to replace the hot water coil (it bolts on,) with an electric heating element? We don't use the hot H2O coil, anyway. The wood boiler is rated at 70, 000 Btu.. If the changeover works, I'm guessing I won't have to change much else, other than a bigger expansion tank and a few controls, maybe... Thanks for your help! (Upstate NY Frank)
