Good afternoon,
I've been running a Tennessee Outdoor Furnace 300 for two seasons. It has performed satisfactorily, but I'm trying to get the most out of it. I've been doing a lot of reading around the internet and I've got a few questions that maybe you guys can help with.
First of all, adding firebrick to the firebox. I've read both pros and cons. From everything I've read, it looks like I'd get the biggest bang for my buck by lining the floor and possibly half way up the sides, since this is a boiler and I still want good heat transfer to the water.
Secondly, obtaining a secondary burn. I've seen several designs out there for DIY'er like myself. I've done a crude drawing of what I'm thinking of doing based on a design that I saw on this site. That post is several years old so that's why I'm posting a new post about it. My particular model boiler is power draft fed through a tube from the back of the boiler to the front. My though was to run a pipe from the top of the draft tube, tee it off to both sides of the firebox, run the pipe to the front of the unit and make a u-turn to the back of the unit. Than I would have tubes running across the top of the firebox with outlet holes pointing down. I would assume, running the air-flow in this manner would heat the air prior to exhausting onto the fire.
Any thoughts on either of these two would be greatly appreciated.
As an aside, I've been burning both wood and bituminous coal. Lately just bit coal since I can get it a lot cheaper than buying cord wood, since I rarely have time to cut and split my own.
Pic 1: Unadulterated Firebox - Note, this is an older model. My model does not have the tube coming down in the back.
Pic 2: Planned upgrade
Pic 3: Design based off of
Thanks,
![Conventional Boiler Upgrade - DIY Conventional Boiler Upgrade - DIY](https://www.hearth.com/talk/data/attachments/175/175231-335a2bf987cc995672e6c205d72521e7.jpg)
Thanks,
![Conventional Boiler Upgrade - DIY Conventional Boiler Upgrade - DIY](https://www.hearth.com/talk/data/attachments/175/175229-80ba4c5c19a4c860994b47db87b3b58d.jpg)
![Conventional Boiler Upgrade - DIY Conventional Boiler Upgrade - DIY](https://www.hearth.com/talk/data/attachments/175/175230-9de8b6c24622f68883fb8549bbdfa4cf.jpg)
