hi new here not sure this is the right place to post, but here goes.
I have a wood stove and a metal flue liner in the chimney, so far i have cut a opening in the chimney up in the bedroom so when the fire is lit hot air comes out of it, so i can warm the room above well.
I am looking to build on that by making an opening in the chimney within the loft with a fan fitted so it blowes air in to the chimney , the air would then come out in the opening in the bedroom, i am also going to run ductin to other bedrooms from openings i will creat in the chimney??
thoughts please?
AT present the way the air comes out in the bedroom is because i have not installed a register plate above the stove, but i want to install the register plate and taking air from the loft seems most sensible option ?
thoughts please?
