My cleaning rods slides, (3 plates that slide up the tubes are loose & Bind on tubes) the rods are tight I cant use them only when a pull the chamber walls down and run them by hand. anything I can do?
Ah, now I get it. The weld that holds the scraper in place on the rod has failed. With my old stove, the metal simply had fatigued from all the stress and heat, and it just tore out.the plates are all loose on the pull rods and bind on the tubes, I have to take the stove apart and hold them as I pull the rods up and down.
