My stove (year 2000) calls for heat, ignites, drops pellets, and then lags to turn convection blower on (15+ minutes). Once it reaches temp, the convection blower lags to shut off... 30+ minutes after exhaust blower does. It's super noisy on startup too- grinding metallic noise, but that fades off after the fins spin for a while.. when it is blowing air, it pumps it out like crazy.
Could my control box be getting delayed temperature read from thermocouple somehow? The feed motor seems to come on timely.
The problem is my convection blower is late for the party, super loud at times, and then stays partying too long after the fire goes out
This was not an issue last season prior to a thorough cleaning and maintenance
Here is my thought pattern. Looking for some help from a seasoned quad vet:
Thermocouple- tested with voltmeter and is OK I believe, the end is a little frayed, but snap discs are opening and closing, which means control box is getting a read on temps correct??
Thermocouple cover- new- just replaced
Snap discs 1 and 2- these can't be the issue right? Feed motor and fans coming on and off...
Firepot gasket- new- just replaced
Ash pan- gasket seems OK, securely latched
Door Gasket - not perfect (rope is frayed in spots) but passes the dollar bill test
Heat exchanger tubes all thoroughly cleaned recently, exhaust path is clear and the stove purrs with vacuum, so I don't think any air flow issues. Any ideas?
