Controlling combustion blower speeds?
shooter64738
2
Usa
Hello all!
Few weeks ago my control board failed middle of the night, and at 6 degrees outside, I couldn't wait around for parts.
Using a micro controller and some realys I cobbled together something to get me by. Its been 2 weeks now and the stove burns hotter, makes less ash, and uses fewer pellets. Not by a bunch, but I can go 28 hours now between refills instead of 24.
Question is, if I do run the combustion blower via relay, its always on 'high' and the previous dead control ran at a lower speed during ignition and higher apeed after lighting. Is there a benefit to being able to control the combustion fan speed? I can change it out to a triac and vary the speed, but is it neccessary? Will ash build up be worse?
New control comes in friday, but I might just keep tinkering with this some more. Fyi the stove is a heatilator cab50 stove.
Thanks all!
Not sure what failed on your control board, but motor triacs are replaceable.
Quads/Heatilator's don't have effective air dampers so they control the exhaust blowers at the 3 different feed rates. With a full speed exh blower on the lowest heat setting I suspect the fire would run lean and flame out eventually.
Thanks for the info!
Controller wouldnt power on at all, fuses were good. Couldn't find any signals or power to the controller chip, which i think is of the pic variety.
Ive been chaging the duration and frequency of the pellet drops depending on requested temperature. I was just wondering if exhaust speed should be variable, or if full on was appropriate. I may replace the stock controller with this one. Its certainly easier to maintain.
