I've got a Vigas 60.. the firebox is about 30 long and 25 or so wide. When I first started cutting... I was lax about length and mostly cut 18 to 20 inch stuff. I've since got into a good routine about getting 23 to 24 inch splits.
My wonder is this.. After I have a bed of coals going... What about loading the box full with the splits perpendicular to the nozzles. Call it parallel with the door. I seem to open the door anyway about 3/4 the way thru the burn and stir up / recover the nozzle... and reload.
I guess I'm just not seeing how everything is supposed to keep falling into the middle better if the stacks are parallel with the nozzle. With my 18" wood.. I seem to have funny piles with wood either touching the back or the front.. Lots of air space. If I turned it the other way, it could be stuffed full as the splits would just have a few inches on each side of them.
Probably doesn't matter a bit.. But I am enjoying burning. I've realized that if I crank the boiler up on the computer to +2... my marginal wood burns much better. Since I'm batch burning, and keeping my stack temps in the low 3s... Mark says i'm in the sweet spot for the boiler.
JP
JP
