Howdy again,
We upgraded a beat-up Florida room to something nice after a terrific hailstorm, high winds, downed trees, etc. We used the insurance proceeds and ponied up the difference. Had a reputable general contracting company (we thought) and a guy onsite to supervise daily stuff. The whole experience is still somewhat traumatic...
I've heard the word "flashing" before and I know some big problem comes next in the sentence, but that's it. I wouldn't have known to demand it or if it was done properly, but I think in this case it wasn't done at all.
Heavy rains result in a puddle of water coming in the sunroom from under a baseboard. Outside, I've caulked, re-caulked, cleaned out the caulk and caulked again. In March 2015 a guy who replaced our soffits ginned up another attempt with some external flashing and silicone. It worked for a while but a storm last week did dump some rain and the puddle came back.
I finally pulled off the baseboards to inspect and there's lots of water there. I made a dye to put in a puddle outside and the color slowly began to appear inside so it's definitely coming from the floor and not the wall or windows. The drywall inside is dry.
Called a BIL who does some construction and we removed a bottom run of vinyl siding and then we saw the problem. The bottom several inches of OSB are toast. There was some j-lock to terminate the siding with a tiny bead of caulk on the side facing in - seemingly wholly inadequate.
Right now the plan is to cut out/replace the damaged OSB, bend flashing into a tall "L" shape, and put it down like the world depends on it.
I saw copper being used as flashing and thought that was pretty smart. If you guys have any tips or online resources let me know and I'll dig into it. The pics should make the problem fairly clear.
Thanks,
Greg
![Contractor didn't use flashing - Sunroom has a big problem Contractor didn't use flashing - Sunroom has a big problem](https://www.hearth.com/talk/data/attachments/165/165621-2c12342010cc66fc54227d4eb85dffad.jpg)
![Contractor didn't use flashing - Sunroom has a big problem Contractor didn't use flashing - Sunroom has a big problem](https://www.hearth.com/talk/data/attachments/165/165623-290ba61d1f8ca7e19542ea6b9f4fff61.jpg)
![Contractor didn't use flashing - Sunroom has a big problem Contractor didn't use flashing - Sunroom has a big problem](https://www.hearth.com/talk/data/attachments/165/165624-d6f675bd659c29b9aef62e32d7338fb8.jpg)
![Contractor didn't use flashing - Sunroom has a big problem Contractor didn't use flashing - Sunroom has a big problem](https://www.hearth.com/talk/data/attachments/165/165625-d34c614ef6dc1aa476ed7083cc297ede.jpg)
![Contractor didn't use flashing - Sunroom has a big problem Contractor didn't use flashing - Sunroom has a big problem](https://www.hearth.com/talk/data/attachments/165/165619-9c6cdb0d463f4709751e681c4e4bfb7a.jpg)
![Contractor didn't use flashing - Sunroom has a big problem Contractor didn't use flashing - Sunroom has a big problem](https://www.hearth.com/talk/data/attachments/165/165622-80e7d834f8dfec8ff9431b85e47e48b7.jpg)
![Contractor didn't use flashing - Sunroom has a big problem Contractor didn't use flashing - Sunroom has a big problem](https://www.hearth.com/talk/data/attachments/165/165620-4710ae21a310c3071b0a934e1c425dc9.jpg)
Thanks,
Greg
