I have a tee support installation through a concrete wall. From the tee there are two 9 inch duraplus sections that go to the thimple and connector.... I had no problem snapping the connector into the wall thimble and it seems to snug into the dvl pipe really well.... The problem is that the conector does not seem to snug into the duraplus end very well at all. There is only about 1" of connector that shows on the inside of the thimble and that includes the part of the thimble that the connector snaps into. It slides into the duraplus section easily but seems to be a loose conncection and can be removed very easily. So my concern is that there is only one inch of overlap where the connector goes into the duraplus and it is a very loose connection.... It does not snap in or seat itself in any way.... I am wondering if this is normal.... If not how do I fix the problem....
Last question is when I join the connector to the duraplus there seems to be small voids around the inside wall where it seems like smoke will escape through the inside wall of the pipe.... Will these somehow seal themselves???? It also seems as though these voids are unavoidable as they seem to be made where the inside walls of the pipe were crimped together...
Thanks!
Thanks!
