Hey guys,
So I have the stainless liner down my chimney fully installed and my stove attached to the wall. The problem that I have not been able to overcome is figuring out how to finish connecting what you see here on the stove to the tee inside the chimney. I have several adapters and several pieces of telescoping/adjustable pipe and only the setup you see before you works. Some of them come very close but they are either just too short or just too long.
So the adapter you see in the left of the first picture is what you see on the wall that is connected to the stove in the last picture for reference. It is a double wall to thimble adapter. The next two pieces are a combo stainless telescoping pair, the third (black piece) is an adapter. That adapter allows me to connect the telescoping piece(s) to the next (fourth) piece of stainless pipe you see. Finally the small collar is the snout that needs to be permanently fixed to the final piece of stainless pipe to connect to the tee. The second picture is the opposite side with the pipe assembled the way I want it to go through the thimble.
I was hoping to get some feedback on what you guys think of this? I was told to avoid using stove pipe like this in the thimble because it simply would not last as long. After I install it I plan to buy a couple more to have in the future in case I do need them. They are not expensive.
![Connecting Stove Through Thimble to Stainless Tee Connecting Stove Through Thimble to Stainless Tee](https://www.hearth.com/talk/data/attachments/322/322553-8266c38d1f1a95111b15ecf881d0b5e6.jpg)
![Connecting Stove Through Thimble to Stainless Tee Connecting Stove Through Thimble to Stainless Tee](https://www.hearth.com/talk/data/attachments/322/322554-f3f351939dc584d47f2f626eb5a2e8e6.jpg)
![Connecting Stove Through Thimble to Stainless Tee Connecting Stove Through Thimble to Stainless Tee](https://www.hearth.com/talk/data/attachments/322/322552-060301d64e56c43adcd4b66720549420.jpg)
