Hey all, have lurked here for awhile but finally have a question to post. I'm doing some renos and need to move the location of my stove thimble in the wall, lower by about 30" and approx 18" to the side. Currently I have a masonry chimney with a flexible stainless liner. Im trying to figure out the best way to connect the new thimble location to the existing liner if possible?
My current thought was to connect class A pipe between the two. A tee with a cap on the thimble, a 15 or 30 elbow on top of that, an angled length of pipe to get into the chimney under the existing liner, and then another elbow to tie into the liner. The main thing im not sure on, is it possible to tie a liner into the top of a Class A pipe? Will the crimped end of the liner fit into a Class A black pipe adapter or are they meant to be male only?
Also open to suggestions on better ways to do this. Considered running Class A all the way up but i dont think my flues are big enough (8x8 clay liners). Also considered bricking in the area between the existing chimney and the thimble, and running a new liner all the way but not sure if liners can be run around curves. See the attached picture, thanks in advance for any help!
![Chimney Update.png Chimney Update.png](https://www.hearth.com/talk/data/attachments/296/296803-70601996da9ddb188c71fdbaa970ad78.jpg)
