(broken link removed to http://picasaweb.google.com/zanprice1/ChimneyLinerInstall#5534966035351331074)
See photo at link above. I have a six-inch rigid tee I need to connect to double wall stove pipe. The outside diameter of the tee is slightly larger than 6". Is there an adapter I need to use to securely attach this to the double wall pipe?
Note that I will likely shorten the length of the tee coming out of the thimble so I can make the connection at the tee.
