Condar Inferno vs. PTC 314F
lumbering on
482
New York
About to by a thermometer.
Condar inferno $20 plus $5 shipping.
PTC 314F $38 plus $12 dollars shipping.
I read the condar is pretty good, but PTC is higher quality. I don't want to have to replace the condar after a season or two whenI could have bought higher quality to start.
I've seen both recommended on the site. Is the PTC worth the extra money?
Hmm, the PTC that goes up to 750 that I've seen runs in the 45-50 dollar range. Got a link to the one for 38? (edit: think I found it. Were you shopping here? (broken link removed to http://www.ktagage.com/Product_Surface_Temperature_Thermometers.asp)) If you were looking at the one that reads up to 500, that isn't enough for a stove top. Depending on what happens / how that thing is built, if you even take the 750 over 750 by accident, you could ruin an expensive thermometer quickly.
After 2 seasons on 2 condars, I don't see either showing any signs of fatigue and it's been up to 850 for the one on the stove top a number of times.
pen
Hmm, the PTC that goes up to 750 that I've seen runs in the 45-50 dollar range. Got a link to the one for 38? (edit: think I found it. Were you shopping here? (broken link removed to http://www.ktagage.com/Product_Surface_Temperature_Thermometers.asp)) If you were looking at the one that reads up to 500, that isn't enough for a stove top. Depending on what happens if you even take the 750 over 750 by accident, you could ruin an expensive thermometer quickly.
pen
+1 on the condar, I had mine on the steel stove prior to the stone one they have seen 700-800 deg more than once in the past (on the steel stove top that is) 5th year and still works like new, magnet and temp. I IR gun them now and then to be sure. Money well spent in my book.
Todd2
My Condar survived when my Leyden went Nuclear. It reads 900+, and it was pegged! If it can survive that, then it's a good one.
I'm not sure what Woodstock charges for shipping to your location (ouch it's 13.75 for mine making the thermometer be about 25 bux), but this is a Condar thermometer with a scale that woodstock soapstone asked to have put on it for their stoves.
http://store.woodstove.com/product.php?productid=16283&cat=298&page=1
It's 12 bux from them and is the one that I run. Only visual difference is the Condar inferno has a "redline" marking of 650, where this one branded for woodstock has a redline of 675
Here is a pic posted by member Charly. Hope he sees this and chimes in.
This shows the woodstock branded condar thermometer that I mentioned next to what looks like a PTC
[Hearth.com] Condar Inferno vs. PTC 314F
https://www.hearth.com/talk/threads...-1-been-this-cold-before.101982/#post-1314036
pen
My Woodstock Condar cost $2950
came with the stove of corse, lol
Here's the link for the PTC, the manufacturer's site, I believe.
(broken link removed to http://www.ptc1.com/thermometers_surface_dm.htm)
I have 2 Condars - place them both on top of stove on either side per the Castine recommendation. Often they read differently, but I can see why based on flames greater on one sider vs. the other. I usually will open the stove up, poke it around a bit to get more flame on the lower reading side so I get closer to an equal reading.
That interesting that they read differently, do they even after the stove has been running for a while?
I'm also pretty sure Jotul wasn't meaning for the customer to actually use 2 thermometers. In the manual, they are just simply showing that the thermometer can go either side of the stove.
But it never hurts to be cautious!
I bought 2 to check to see of any air leaks on one side vs. the other, not really a Jotul recommendation.
Use an IR thermometer, and move that sucker across the stove top and you'll see there are variations all over, all of the time.
pen
pen
With the IR I see pretty big differences but the magnetic isn't as responsive, kinda hard too tell much of a difference.
Oh I see.
It had come before at some point, the manual for the Oslo shows a thermometer in each of the corners. One person thought that Jotul wanted you to do this, they didn't realize that it was simply a demonstration.
Happy with my Condars.
Charly doesn't like the quality of the PTC themo's!!!
(there ya go, that aught to stir him up to post here!)
Just kidding of course, he said they are the same or better quality than some of the others.... ;)
I'll take an accurate reading, glass covered thermometer with a simple black on white dial any day. A good one will last a long time. This one is 34 yrs old and still doing the job.
