Todd said:
Well I received my Condar probe thermometer and it doesn't work! All it reads is "PROBE"! I followed all the directions and there is no trouble shooting guide. It automaticlly turns off after 30 minutes. What a piece of crap
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
You pay $90 for a thermometer you expect it to work!
Todd, hang on. It may be fine. It doesn't start displaying anything but 'PROB' or 'COOL' until it reaches 500*F. That can take a while. Assuming you have the cable plugged into the display and the probe plugged into the stove properly, which you should verify first.
This is my second season and I love my Condar probe. Take a deep breath, check your cable-probe-stove and cable-plug-displayUnit connections, build a big fire, engage cat as usual, and see what happens.
I had a couple scares like that, too. The first time I saw "PROB" was on the third or fourth day, so it really scared me. I thought it meant "PROBlem". Up until then, it had only said "COOL" when there was no fire.
If the thing still doesn't work after you've tried it in the stove. I'm assuming you installed it and are not just expecting to see the room temperature. You'd only see a reading other than 'PROB' or 'COOL' at room temp if you live in Hades.
It is DESIGNED to turn off after 30 minutes. That is so it doesn't run the battery down with that high draw LED display. That is why I recommended the A/C power converter. So no problem there, at least not with the display instrument. I guess you could argue you'd like it to stay on longer, but that's just how it works. I find it a nice way to time things (kindling stage and open door burn = 30 mins, cat warm up = 30 mins, beer in freezer = yikes!) myself and I simply keep a 20 foot, one inch tape measure handy to reach out and turn it back on without ever lifting my lazy duff off the couch.
Let us know what you discover. If it doesn't work, I'll bet Condar will happily refund your money. I'm just guessing, but if the refund people are as polite and helpful as the technical folks I spoke with, there should be no problem... whatever you decide to do.
Please, do let us know what happens...
