After much back and forth I've decided on a poured in place concrete tank. The tank will be about 700 gals and roughly half of the volume will be below grade.
I have 2 questions for the group:
1. Where should my insulation be, outside or inside (or both)the tank?
2. Would one of the liquid EPDM products work as a sealant? Some are rated to 300 degrees. (broken link removed)
It does not say if this in at constant temp, and I would doubt that it is. The regular EPDM liner with its max temp of 175-180 scares me a bit...
Thanks,
Paul
Thanks,
Paul
