Ok, maybe a stupid question, is anyone burning Envi or other compressed sawdust bricks in a cat stove? For what it's worth, I burn them regularly in my Hearthstone without over firing or getting out of control.
No problem as long as they are the highly compressed variety (NIELs, Homefires, Bio Bricks, Envi Bricks, etc.) and not the flakey cheapos.Ok, maybe a stupid question, is anyone burning Envi or other compressed sawdust bricks in a cat stove? For what it's worth, I burn them regularly in my Hearthstone without over firing or getting out of control.
You can burn such bricks in a cat stove, as long as there are no additives. I.e. just pure wood/shavings/dust.
That seems to be the case with Envi bricks.
In fact, some here advocate to buy a pallet of such bricks when buying a stove, because most people don't ahve enough dry wood stacked up when the stove is installed.
If you can control it well, it's not an issue. For a first time user of the bricks, I'd put in 3 or so, keep an eye on the stove to avoid it taking off, and get a feel for it. (Similar for e.g. burning untreated 2x4 cut
Thanks Begreen. I have three tons of Envi 8s in the basement!Stock up early. I suspect the demand will be high this year.
What is also paramount, is the source of raw materials. One brand tested from the PNW admitted their feedstock was often drift wood. The saline count was not favorable to any wood stove, let alone a catalytic wood stove. The good thing about NIEL's, they are not anywhere near the ocean! We have done very extensive, proprietary analysis of various (but not all) manufactured fuels. These lab studies have shown "most are organic" but some contained melamine and other materials that should not be burned in any stove.No problem as long as they are the highly compressed variety (NIELs, Homefires, Bio Bricks, Envi Bricks, etc.) and not the flakey cheapos.
Of course I can't do that, But you can call them. When we did our sampling, we called and asked for samples. (I should have had a disclaimer that said.. "If you supply us a sample, the results may be made public". Anyway, when the results came back, we called each company and said, "where do you get your feedstock?" That is when we received a response, "pallets, yes. Drift wood, yes. Melamine or OSB, yes." Just because a log looks "denser", that does not assure you of their ingredients.That's a bummer. It would be good to identify those offenders. Some of the cheapo sawdust logs look like they were packed floor sweepings. Typically they expand badly on heating and leave a lot of ash. Homefires and NIELs are denser than water and stay solid down to the end of their burn.
PM me the dealer and I speak with them.Hmmm I was just down at my stove dealer and asked about Bio Bricks. He said to not use them in a Cat Stove. Said it would burn out the cat and void the warranty
I can state for the record, our thermostat can control the burn rate. We can only suggest that not all manufactured fuels are the same. Some have byproducts or other contaminates that can harm ANY stove. One log we had tested was very high in salt content. The feedstock "may include logs scavenged in the form of drift wood". So buyer beware of what you feed your stove.PM me the dealer and I speak with them.
I looked in the installation manual and there is a warranty exclusion for using compressed pre-manufactured logs. I am assuming that he had to say that to cover his butt. Basically the warranty exclusion is for burning anything except seasoned cordwood. Interestingly the exclusion includes Kiln-Dried wood too.PM me the dealer and I speak with them.
You see that is the issue with emission testing to EPA requirements (methods). Forgive the simplicity of this statement:I looked in the installation manual and there is a warranty exclusion for using compressed pre-manufactured logs. I am assuming that he had to say that to cover his butt. Basically the warranty exclusion is for burning anything except seasoned cordwood. Interestingly the exclusion includes Kiln-Dried wood too.
So you can't cover the hole any further, but the amount of air (in cfm's) being pulled into the firebox increases vastly. Whether is is catalytic or secondary combustion doesn't matter, you are subject to increasing burn rates. (Over firing) The best way to address this is to use a some form of automation that can continually reduce the amount of air permitted to enter the firebox. It protects the stove (and in catalytic models the combustor) and provides control of the heat output and fuel consumption.Well done!I used wood bricks in a couple cat stoves with great success. I used them to fill in the void around the wood for those long overnight burns.View attachment 305909
How many hours of burn time (hours in catalytic range and hours to enough hot coal left for a quick restart) do you get with such load in your insert?I used wood bricks in a couple cat stoves with great success. I used them to fill in the void around the wood for those long overnight burns.View attachment 305909
12 hours easily in my Appalachian and 14 hours running the BK on low.How many hours of burn time (hours in catalytic range and hours to enough hot coal left for a quick restart) do you get with such load in your insert?
Just be sure theres no additives and you can burn that till your heart is content (or you run out)Ok, maybe a stupid question, is anyone burning Envi or other compressed sawdust bricks in a cat stove? For what it's worth, I burn them regularly in my Hearthstone without over firing or getting out of control.
