Comfortbilt HP 41
Suestove
3
Massachusetts
Hi. My Comfortbilt Alpine HP 41 is burning through two bags or more of pellets per day. It’s in manual mode in heat level 2. The recommended feed rate is On 6 Off 40, but I don’t know what that means. Does anyone know how I can adjust the feed rate to use less pellets? If I put the stove down to heat level 1 it usually shuts down.
Any help would be appreciated!
6on 40 off means the auger is turned on for 6 seconds and then is off for 40 seconds. I will see if i can get JeffRemington to give tou a hand with this he sell & installs them. The settings have to be in the menus they have 12 pages of operation instructions
Your stove must be raging at that rate.
[Hearth.com] Comfortbilt HP 41
I bought a hp40 in mid-January 2025. I started not getting any heat, even on 5 and discovered that I needed to brush out the vent pipes every week or 2. Every week I empty the tee, vacuum the exhaust chamber, and clean the heat exchangertoo. This improved the heating and I used less pellets. We had some 60 and 70 degree days then a week of below zero, at night, so I cleaned out everything before and after the artic blast. At first I thought the heating issue was the feed rate but cleaning it was what was needed.
