I turned on my pellet stove last night for the first time. I was a little nervous since I recently took of the exhaust pipe, swep the flue etc. It started fine but I seemed to smell some smoke which I only do at initial start up so I backed the thermostat so it would shut down then I turned off a wall switch which shuts off the power. Today I pulled the unit out to check for tightness of the stainless steel clamp to the exhaust manifold near combustion blower. When I went to turn it on, the call light came on and the element heated up, but the combustion blower didn't turn on. I attempted to test for voltage at the blower with both connectors disconnected and there was current as it welded my tester, sparked and tripped the fuse which I later reset(rocker type fuse). I looked at my manual and found the disc3 and pressed the little red reset button, but still nothing. Is it possible the blower died? This year will be the stove's 6th season and it has been flawless until now. My thought was maybe the combustion blower was weak last night and not forcing the exhaust with enough pressure up the chimney. The blower is not stuck and spins easily by hand. The blower has two connections, one with a blue wire and another with a two white wires. The connector on the blower going to the blue wire pulled out but I was able to snap it back in. Could this be a source of the problem? THanks for your help. Greg
