My goal is to achieve a clean burning fire as quickly as possible using a top down fire. I figure that comes down to heating the flue as quickly as possible (discourage condensation/creosote, get good draft) and then the stove (enable secondaries, thus less creosote/pollution/waste). I've searched through old threads about if it's possible (without trying anything crazy) to heat a cold steel stove up too quickly and, within reason, I believe not.
So I'm planning on going heavy with the kindling next time to get things going hot ASAP, then let their embers take care of the bigger logs down on the bottom. With total fuel load not being great, I'm not so concerned about over firing the stove as I am about possibly warping my new PE's baffle. So any thoughts out there about (1) going heavy on kindling and (2) warping the baffle just from quick kindling heat?
The idea of the heavy kindling cold start came from the EPA report for the Jotul F54 V2. (page 521) They used 10 (!) lbs of kindling and start-up fuel pieces. I've included some of that report below.
I'm not a 24/7 burner, thus cold starts are a way of life for me. This is also my first season with a Kindling Cracker, so for now making more kindling doesn't bother me.
Thanks.
(I failed at trying to copy the page from the Jotul 45v2 epa report which included pictures. Here's some text from page 521 of that report.)
High Fire with a Cold Start
To start the fire from a “cold” stove:
1. Cut and split 12 kindling pieces 16 inches long. Half of them should be approximately ¾ inch
square, the rest ½ inch square. Cut and split 4 kindling pieces 12 inches long, about ½ inch
square. The kindling should be very dry and weigh approximately 3.5lbs
2. Cut and split 8 start-up fuel pieces 16 inches long and 1 ½ inches square. Cut and split 4 start-up
fuel pieces 12 inches long, two 1 ½ inches square and two that are ¾ inches square. These can
be split from larger fuel pieces that are in the range of 19-25% moisture (Dry-basis). The total
weight of the start-up fuel should be approximately 6.5 lbs.
3. Arrange the start-up fuel pieces in a grid on the bottom of the firebox with short pieces side to
side and long pieces running front to back. First on the bottom the larger 12 inch pieces side to
side about 10 inches apart. Next place the 4 larger 16 inch pieces front to back on top of the 12
inch pieces. Next the 2 remaining cross pieces and the 4 remaining long pieces on top.
4. Next arrange the kindling pieces in a similar grid pattern with the larger pieces first followed by
the smallest.
Thanks.
the smallest.
