We built a house 3 years ago and the builder installed a DESA direct-vent gas fireplace. Ever since it was installed, we have had constant problems in the winter with cold air coming from the front into our living room. The builder took the siding off the outside chase and reinsulated the outside box, as well as insulating under the box (it's on a raised hearth). That made the problem better but didn't solve it completely.
That side of the house is exposed to the west and when the winds blow the draft gets worse. We have been forced to tape a blanket up in front of the fireplace to cut down on the heat loss. Is there some kind of insulating blanket that can be custom made to cover the opening - which can be readily removed when we want to use it?
Thanks!
akronguy
Thanks!
akronguy
