How high does a wall protecting heat shield need to extend above a stove?
I am planning to install a Hearthstone Mansfield in a parallel installation. The Mansfield manual calls for a clearance to protected surfaces (NFPA 211) of 10 inches to the side and 8 in. to the rear (using factory heat shield and double wall pipe).
I will be constructing the wall heat shield with 1/2 inch Durock cement board and tile, spaced 1.5 in. from floor and an inch of air space between the wall.
