Hi, all
Recent lurker, and there's been some great advice that I've read about how to operate a wood stove that I have found invaluable. Here is my story: moved into a raised ranch 4 years ago that had a big Coalbrookdale Severn multifuel stove in the den/ground floor. Didn't use it for the first three years, but the electric baseboard heat bills got to be too much. So we decided to start using the stove. Had a sweep come in, everything clean and ship shape, recommended the bio bricks, off we went. Did loads of reading about how to operate it, especially here.
Recently though, I noticed that the bricks in the back were cracked. So I got some refractory mortar to patch the cracks up. I might have got the wrong stuff though, because last week one of the bricks started tilting forward, at the crack. So I let the stove cool down over 2 days, and remove the bricks, which literally crumble in my hands. It was the bricks, so I thought "I'll just get three from store or Amazon. Got a pack of 6 Rutland bricks. The problem? The widths of the original bricks aren't consistent. It's two standard 9x4.5x1.25 inch bricks, and then a central 9x3.75x1.25 brick. I tried to trim I've of the Rutland bricks down using the chisel, but they kept breaking in half. I managed to find a 9x4x1.25 brick set, so I got two, and filled and sanded 1/4 of an inch off over side of the clay brick. Hurrah! All three now fit.
Except.
They keep tipping forward.
I hoped they would expand with the heat and clamp each other in. But they haven't.
So my question.
How do I solve this? Are there clips/brackets I can use? Or should I just go ahead and mortar the sides and the bricks to reach other?
It's such a good stove to use, even with only 44000btu output, for our small house. But that bricks thing is annoying me. And Lord knows what I'll do if the irregular-shaped side bricks ever go![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thanks in advance!
Here is a picture of it in all it's glory!
![Coalbrookdale Severn non-boiler - fire brick issue Coalbrookdale Severn non-boiler - fire brick issue](https://www.hearth.com/talk/data/attachments/292/292138-97ffb62663235e7991016814326fb276.jpg)
Except.
So my question.
Thanks in advance!
