I can't seem to get the temp.(top center of insert) any hotter than 500 degrees. Does this seem normal? I'm burning 2 year oak. What is a good insert top temp. to produce heat on a 30 degree night.
My max temps. are the same as yours. The 700 temps all seemed to be stoves. I wasn't sure if the Clydesdale should be able to run that hot.BroadCove said:I doubt any Clydesdale owners run anywhere close to 700 degrees, measured on the top front of the stove (the only real place to put a magnetic thermometer on these) on a regular basis. My peak temps are usually in the 450-550 range.
j&sclydesdale; said:We cant seem to get our Clydesdale above 400 and if it does get to 400 it doesnt stay there long. Usually levels out around 250-300. Any suggestions?
