Stove Chows are HD's best pellets and obviously they don't know this cause they sell for theJust closed down my stove today.Moving to a new house in a month.Hope to bring the pellet monster with me.I will no longer be a basement dweller.![]()
This Cape Cod, the bay is still cold and I'll probably be burning at least at night for another month yet. get a North wind and you get nailed with a mid 40s day and fog. But ya you have a good idea there. You might want to change it out in mid summer, it could be saturated by then.Anyone else put "damp rid" in there Ash pan for the summer and fall?
The walls inside my stove have a light brown tacky coating on them.. I assume I should use a mild abrassive like a scouring pad[scotch-brite] and clean the side and back walls 1st before applying the cooking spray? or do u just spray the burnpot.....Just in the firebox. And based on the advice of others here, I spray the entire fire box with Pam cooking oil as a finishing touch.
Clean everything, or as much as you can before you close off the stove. The coating you are describing is creosote. I use a wire brush. I spray the entire fire chamber. The oil helps prevent surface rust.The walls inside my stove have a light brown tacky coating on them.. I assume I should use a mild abrassive like a scouring pad[scotch-brite] and clean the side and back walls 1st before applying the cooking spray? or do u just spray the burnpot.....
ok.... thanks for the tips...have some foam sanding blocks might work also.Clean everything, or as much as you can before you close off the stove. The coating you are describing is creosote. I use a wire brush. I spray the entire fire chamber. The oil helps prevent surface rust.
I would assume that WD would be pretty much dried up by heating season 6months?... May-November....This is the first I have read of coating the stove after winter use... I would think Pam spray would attract bugs because it is vegetable based? WD 40 would smell and create fire issue? The only thing I coat is my table saw top - use floor wax. If lazy, I use WD 40 over the winter.
Had a bat get in mine which prompted me to start capping it.Pellet puppy in the basement is down for the season. May need the wood stove a night or two next week but it is beautiful here at the moment and supposed to stay that way until Tuesday.
Never heard of anybody having bug problems with Pam in the stove.
