Closing down a heating zone for the winter
machinistbcb
109
Sabattus Maine
My Father has asked me to help close off a baseboard hot water zone in a area of his house that he wants to close off for the winter. What and how is the best way to close off a zone and make sure there is no water in the pipes that could freeze.
Thanks, Brian
Add valves (ball valves, not gate valves) and purge tees (a tee with a boiler drain attached) at each end of the loop. The boiler drains have standard hose connections - make up a fitting so you can connect an air compressor to one end, and blow the water out the other end.
Edited to add: to make a quick-and-dirty fitting for getting air into the piping, just take a washing machine hose and cut it, then connect an air compressor quick-connect fitting to a valve, and install a hose barb in the other end of the valve. Insert the hose barb into the cut end of the washing machine hose, and you're all set.
Joe
Joe's suggestion is right on the money. If you don't have a high-capacity air compressor, a Shop-Vac does a credible job of sucking water out of plumbing. You'll want to make sure that you don't have any small orifices in the path, but otherwise it does a good job.
