verge32 said:I have a quad classic bay 1200 insert. The only control is the pellet feedrate (besides low med hi).
rap69ri said:It depends on the pellets and airflow. You could try increasing the airflow to the burnpot, or slowing down the pellet feed rate. It may also be that your stove needs a good cleaning.
What stove do you have?
rap69ri said:verge32 said:I have a quad classic bay 1200 insert. The only control is the pellet feedrate (besides low med hi).
There's no draft seetings on your stove?
I think it's the pellets.verge32 said:I have a quad classic bay 1200 insert. The only control is the pellet feedrate (besides low med hi).
Ductape said:Does a clinker resemble a turd?
Shooter said:I think it's the pellets.verge32 said:I have a quad classic bay 1200 insert. The only control is the pellet feedrate (besides low med hi).
I'm using Maeder Bros pellets and I get a "cake" of pumice-like substance at the bottom of the pot that needs to be emptied morning and evening. These pellets are so far the only that will do this.
For me, it's not airflow because as big as that cake can get it will still have airholes formed in the cake....and the flame keeps burning.
I too, have a CB1200i and it's a great stove!
geek said:rap69ri said:It depends on the pellets and airflow. You could try increasing the airflow to the burnpot, or slowing down the pellet feed rate. It may also be that your stove needs a good cleaning.
hey Rick, do you know if this also applies to the 25-PDV, I know you have the 25-PDVC but wondering if these 2 are pretty much the same as far as settings go.
I've seen also lots of clinkers on my stove but changed the settings to 4-6-1 and will see if that improves or not.
I usually start it up at 3-5 (heat range-blower speed) and then after a couple hours I decrease it to 2-3 or 1-1 if not too cold. Wondering also if low settings affect this as well.
Bizarre isnt it?? I can burn 4 other brands of pellets and have just a bit of dust, just give a tug on the pot lever and it dumps. That clinker.....I have to reach in and help it out the bottom or open the front door and get things dusty. This must be done 2 times daily for optimum burning.Panhandler said:Shooter said:I think it's the pellets.verge32 said:I have a quad classic bay 1200 insert. The only control is the pellet feedrate (besides low med hi).
Interesting. I have burned for three previous seasons and had no idea what a clinker was. I always had very fine light colored ash, very light weight. This season I'm getting the "pumice-like substance" (good description by the way) with two different brands of pellets. My air holes are not getting clogged and it is easy to scoop out.
If that were the problem with mine than why do other pellets not even begin to form a clinker? Besides, I clean the air holes and check them regularly.4124elad said:Quads all use the same burn pot and have fixed airflows. If you clean the burnpot in a Quad once a day then clinkers will never be a problem.
If you maintain any stove on a daily basis then any stove pellet or other will never cause you a problem.
