Hello All!
My question relates specifically to installing a Kuma Cascade Insert stove into an existing hearth. Hearth previously had an air circulating fireplace, which was a 1" ceramic tile box inside a doublewall steel box with 1" insulation between the steel walls. Upon partial removal of this fireplace, I have discovered that the alcove or hearth is 2x6 studs and fiberglass insulation, totally exposed to the inside of the hearth.
The Cascade clearance recommendations for the Insert are just blank on the Kuma Specs. Clearances to side and back wall are unlisted, as if there are no requirements. See photo. only clearances are presented from the front of the stove.
I do not like the idea of setting this stove in the wall next to wooden studs. I was thinking of installing some cement board against the studs, beneath of expensive, 1 inch thick fireproof insulation on top of that, facing the stove metal. Assuming that I read this correctly, am I correct in thinking of taking this approach?
Cascade LE insert stove is burly, firebrick walls on a steel wall of the stove, then there is a 1" clear space between similar gauge outer steel walls. I wonder if the outer wall even gets any heat? Thanks for reading and sharing opinions and wisdom.
![Clearances with Insert Wood Stove Clearances with Insert Wood Stove](https://www.hearth.com/talk/data/attachments/293/293021-ddc9dfc9f4745f181afc62dc63640d1d.jpg)
