Ok. I've read a few posts on a similar topic.
But still don't get it. Either that or my abilities to do math are failing.
We'll say single wall vert pipe to keep it simple and establish a ref point. Code says 18" from combustibles. Not from center of pipe, but From.
Notice the 4 attached images all clipped from their manuals.
1. The PE T6 I'll almost buy. It's close at 17.75" from center of pipe. 14.75" from wall.
2. The Enviro Boston 1700 is 15" from pipe, so 18" from center. Again, close to code. But 3" too close.
3. Now the Jotul F55 is 10" (13" from pipe center) With collar shield, which is just a small piece (approx 6"x6") near stove/pipe connection. 18" away without. What about the part of the pipe (most of it) above the shield? Code (not as I am aware) doesn't say 18" away from wall near collar, but 1 ft up, 10" is fine.
4. And the best one, is the Quad Exp 3 at 7" (10.5 from center) with single wall pipe. No mention of any type of pipe heat shield. And dbl wall only buys you an extra inch closer. (6")
I talked with a couple dealers that did confirm the specs were correct (in all cases) and not a misprint.
They were a little baffled as well, and the best answer I got was "we always do 18 away". Which is code, I agree with and think it's fine.......but seriously, what gives? I am missing something, I'm sure, as is usually the case.
I'd rather put my stove back as far (and safely) as I can. The more up front the better. As in coals with minds of their own. I swear......some do.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
