I wind up looking at so many articles on here, I figured I would finally just create an account.
I'm trying to get a wood stove installed in an alcove in my basement, where there used to be a pellet stove installed. I have an older Quadrafire 3100 ACC that I would like to put in here. My concern is the distance from the side of the stove to the side of the alcove it would be partially in:
![[Hearth.com] Clearance to combustibles versus masonry [Hearth.com] Clearance to combustibles versus masonry](https://www.hearth.com/talk/data/attachments/334/334444-dc7216b44321eb647386b12b931dda8d.jpg?hash=0N77GXCJ5I)
The installation information on the back of the stove calls for 13" clearance to the side. If I put this stove in here, I would have 7.25" clearance on each side. However, that would be the distance to a wall that is composed of tile directly over the cinder block wall of the foundation; it's all masonry, which I don't believe counts as a combustible. The nearest combustible material would be 18.25" on each side of the stove.
Can I reduce the clearance when it's going up against masonry, or is that not how it works? I can tell you what the guy from the stove store says, which is that it isn't allowed and I need to buy one of their new $4000 stoves that has different clearance requirements, but I wanted to ask on here.
Thank you!
Thank you!
