I have a specific question about measuring the minimum clearance to combustibles from wood stoves.
The question is this: when you have a wall which has a non-combustible surface layered directly on top of a combustible surface (no air space in between), is the clearance measured to the outer, non-combustible surface or is it measured through the non-combustible material to the combustible material behind it, as if the non-combustible wasn't there?
For example: a stove has a rear clearance of 10". The construction of the wall behind the stove is wood studs, 1/2" drywall on the studs, and 1" brick veneer on the drywall. Is the 10" clearance measured through the brick veneer to the drywall behind, thereby putting the stove 9" from the outer surface of the brick, or is it measured to the outer surface of the brick veneer, placing the stove 10" from the outer surface of the brick?
I've looked up a bunch of threads on the subject but through the years there seems to be differing opinions/final answers. I am familiar with NFPA 211. Is there an official source for the answer to this question one way or another?
