I am still considering installing an older non-listed stove. I want to put it in a corner. If I understand the article below the rear corners of the stove can be 12" from each wall if I shield it with a 24 ga shield one inch from the wall? Suppose I decide to make a thicker stone wall with the same air space, would the reduced stone wall to stove space be an issue?
Is there anywhere I can read the NFPA 211 on line?
Thanks
https://www.hearth.com/econtent/index.php/articles/wood_stove_clearances_installing_it_safely
Thanks
