Does anyone know of a cheap vacuum to vacuum out the inside of the stove when doing a cleaning. I have seen them priced at $275.00. Also how often do you have to take down your stove for a cleaning of the soot buildup?
richg60 said:Does anyone know of a cheap vacuum to vacuum out the inside of the stove when doing a cleaning. I have seen them priced at $275.00. Also how often do you have to take down your stove for a cleaning of the soot buildup?
woodsman23 said:.....(or you can ask slick for some help.)
woodsman23 said:Well if you live on a lower level do what i do and leave the vac outside while cleaning. I have a drywall bag on it and a extension hose attached. I clean everything up and brush into ash pan then vac up the rest. This way there is no dust in the house at all. Works too well.... (or you canb ask slick for some help.)
macman said:woodsman23 said:.....(or you can ask slick for some help.)
I agree with Jay & Woodsman...even a small shop vac will work. Just make sure the stove has sat for at least an hour before cleaning.
This is the one I bought to keep up on the main floor to use w/ the stove, or anything else that comes along. You can get drywall bags that can be cut to fit it too....cheaper than the HEPA filter:
(broken link removed to http://www.homedepot.com/Tools-Hardware-Wet-Dry-Vacuums/h_d1/N-5yc1vZ1xhtZb8pi/R-100638350/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053)
I found it on sale last winter....I think I paid $22.99.
Oh, and DON'T ask SlickPlant about cleaning....she'll go off on a rant about how Woodsman told her to cut her bush because of sparks :lol:
GotzTheHotz said:Jeez, mac, I need to cut the bushes? Please, no, not again!
.......let the stove cool very well, scrape and brush it down, catch as much in the ash pan as possible and empty that, then vac......
StrangeRanger said:I started out doing the shop-vac w/ drywall/hepa filter routine, but found that when you use the super fine particle filters they tend to clog up very quickly and you lose your suction power. I scrimped and saved and got "Santa" to kick in on a Loveless ash vac. Loud? Galdarn right it's loud. But it's all metal w/ a metal hose so worry much less about accidentally sucking up embers. And my favorite feature, basically the reason I suckered myself into it, is that you can "clean" the filter bag w/out having to open the unit up. It's got a little "shaker handle" that allows you to clean/bang off the filter bag at any time so you always have full power. She's gone from suck to blow!!
j
