N
nate379
Guest
What is the easiest way to clean the chimney cap if it can't be reached from the roof without having to tear the chimney apart?
I also use this approach. I usually have wife go outside with the binoculars to tell me when I reach the cap area. I think this year I am going to paint the head of the soot eater a florescent orange/bright color, so its a little easier to see when the head reaches the cap area.You could use a sooteater and get a second head leaving the whips long so they scrub out the inside of the cap.
I left my lines the correct size for the pipe and it worked fine a week ago,, and they had already been previously used... That head oscillates back and forth once the strings pop up out of the pipe and are in the cap area.. I also rotate the drill in both directions once at the cap.I have a soot eater, but the strings are cut to fit the pipe. Should I have left them long??
