I have cleaned a round metal chimney flue that was only about 16 feet tall. I used a brush and fiberglass rods.
In a new location, I need to clean a couple of masonry flues in a brick chimney that is about 35 feet high. The previous owner used fiberglass poles attached to a brush. I was wondering if it might be easier to clean the tall flues with a rope attached to the brush and weight attached to the bottom of the brush. I see they make pull rings to allow rope attachment. I want to work only from the top. Is this a feasible idea? If so, how much weight is usually required? I will be using a 7x7 square brush.
PaulF
PaulF
