Cleaned up the Baltic, for the second time, tonight, since first firing up the stove. Cleaned the glass, also. So the schedule seems to be about once every two weeks, for clean outs, although in a pinch I could certainly go a month, before I would reach the level of the front lip, on this stove. If heard horror stories about using ash pans, but with this stove, using a mix of pine and Eco Bricks, I don't seem to have any trouble with floating or spilled ash or dust. And the ultra low tech cast iron plug doesn't seem to leak any air, either. Glass took a few spritzes of glass cleaner only, since after approximately a month of burning, the only deposits were a dusty, light colored haze. Any dark reposts that did appear, even burning damp wood, never survived the hot part of the burn cycle.
One month in, and not a single black mark on the Baltic's record. It even started right up, with a damp, foggy 47*F outside temp. As long as I've used the bypass, I've never experienced even minor smoke spillage, with an open door.
I've decided to burn for a full season, before writing my review in the reviews section. But, unless I find some pretty major issues, between now and then, it looks to be a pretty positive showing. Put succinctly, this is a simply but very well designed unit. It's easy to run, can go 6-8 hours on dry pine, 10+ hours on bricked fuel, and heats my 1500 sq. ft. poorly insulated house to whatever temperature I want, even in below zero (Fahrenheit) temperatures. If it were any simpler a design, or easier to learn, IMHO, it would have to be a smoke dragon. As you may have surmised, I'm pretty enamored.
Here's a pic of the first fire, after cleaning. Keep in mind that this wood has been out in the rain, until about 30 minutes before it went into the stove. I really like how easy the pine takes off, even under those conditions.
![Cleaned Out the Drolet Baltic ... Cleaned Out the Drolet Baltic ...](/talk/proxy.php?image=http%3A%2F%2Ftapatalk.imageshack.com%2Fv2%2F14%2F12%2F14%2F7ff8cb32b71ddb6461dc30fc40f9c806.jpg&hash=02ac8c2b4bc3d5c5cb0a31e7ab249129)
