So I have fixed/replaced a bunch of parts on this pos over the last 2 years but cant figure out feed problem. Plug it in, call light is on, exhaust motor turns on. Control box blinks once orange, and then I think 5 or 6 times blue very slowly. Cleaned unit. Bench tests motor, works fine. Bypassed vacuum, nothing. Bypassed snap disc 2, nothing. Snap disc 3 is fine / not tripped. The hopper door cut off isnt a issue - i cut that and spliced it 2 months ago because magnetic switch was bad. THermocoupler looks fine, igniter works, just wont send signal to motor. I swear i hear a click in the control box at the time when it would send signal to motor at startup. Any helps would be great - its 4 degrees in Northern NY
